Hi, The lumbar support is not working, I can hear the relay clicking but no movement in lumbar support or bolsters
Following this video to check air hose Click Here removed seat and no breakage in the line. (FYI go instruction for removing seat)
What I did find is below, it's the same on both seats looks like the end of the hose is missing either a cap or a part, no obvious place to plug it in. any thoughts on this and what else I can try to find seat issue.
Checked all the fuses behind the drivers seat all fine. The soft close on the boot works, central locking works, all other seat controls work and the pulse light activates when pressed so electrics look fine.
You can see image below with the seat insitu, it's directly under the lumbar support controls. if possible can somebody check theirs please. Thanks
