Hi Luke,
I need your expert advice.[?]
I drive a 1991 W124 200E with original 6.5 x 15 ET38 x 195 tires.
I intend to replace them with 7.5 x 17 ET35 wheels.
1. Will this wheels fit my W124 200E?
2. Which tire will fit better
a. 225 x 45 x 17 or
b. 205 x 50 x 17
3. What tire pressure will you recommend for front & rear for option 2a. & 2b.
Looking forward to your expert advice & thank you in advance.[:)]
Regards
BenzWorld Tire & Wheel God
17x7.5 ET35 works perfectly on a W124
use a 215/45-17 tire size
tire search link...
tire search link
http://www.tirerack.com/a.jsp?a=CQ4&url=/tires/index.jsp
Re: 17x7.5 ET35 works perfectly on a W124use a 215/45-17 tire sizetire search link
tire search link
Hi Luke,
My orignal wheels are 15 x 6.5 ET38 with 195/65/15
tires which according to your formula for overal diameter = 25"
If I use 215/45-17 tire size the overal diameter would be = 24.6"
Will that affect my speedometer readings?
Thanks again![:D]
BenzWorld W124 Host
1993 300E 3.2L 24V
From what I've heard and know, the effect will be very insignificant. Something in the are...
From what I've heard and know, the effect will be very insignificant. Something in the area of maybe a 1/2 a mph. So you'll be doing about a 1/2mph slower than the speedometer will read. If it's even a half. I know the 225s fit in the exact same size diameter, but Luke said they would rub, seemed odd to me. Luke care to fill me in on why a tire with the exact same overall diameter would rub? I was curious as to why.
-Tubs
if you notice and difference I would be surprised
