1993 300D
I found a set of 17x7 5x112 ET35 off a 1997 Audi A4...will they fit my 1993 300D?
thanks in advance...
Mario
CLK55/G500/E55/ML55/etc.
Mario
If they are hubcentric on the Audi, they will not fit on the W124 without machining the center bore to 66.6mm (the Audi CB is smaller).
-s-
1993 300D
The rims are actually aftermarket...the are made by Flik...if i recall, they are Flik Tita...
The rims are actually aftermarket...the are made by Flik...if i recall, they are Flik Titans...what about the offset and width?
thanks...
Mario
Re: The rims are actually aftermarket...the are made by Flik...if i recall, they are Flik Tita
thanks...
Mario
Offset and width should be fine... I just mounted 16x7 ET35 wheels to my 190E. They stick out a little in the front but the tires do not rub at all. The offset is a bit low for the 190E, and I think it's a bit low for the W124. My friend runs ET30 on his W124 and it is definitely a bit too low.
Although they are aftermarket, they may still be Audi hubcentric. If you can hold them up to your hub you'll see if it clears! They may also have a hubcentric adapter, then you could call up TireRack and get the correct hubcentric adapters.
Hope that helps,
-s-
2002 C230k
Flik wheels
I know of two people who removed Flik wheels from their Audis and mounted them on their new C class cars. Based on that I would say there are hub adapters available.
BenzWorld Tire & Wheel God
Re: Re: Luke...will these rims fit my W124?
Mario
-s-
you are correct sir
