<br>
What does the RF mean on this tire ?<br>
225/35YR18RF Bridgestone Potenza S-03 Pole Position <br>
<br>
I was thinking to use this in front due to lowering w. AMG and it looks like it could scrape <br>
with higher 225/40 what do you think ?<br>
<br>
I would then take 255/35 18 in rear.<br>
<br>
I have the AMG 5 arm 8,o in front and the wider <br>
in back 9,0 or 9,5<br>
<br>
BTW. Does Tirerack send tires via Fedex to Iceland<p>dyna0.islandia.is
Hello Luke !<br> I am considering the following tire & wheel pacakge, and Tirerack fits on tires to the wheels.<br> <br> Would you fit a Bridgestone Potenza S-03 Pole Pos.<br> for my R170<br> 225/35YR18RF to a MM EVO 18x8 for front and<br> 235/40YR18 to a MM EVO 18x9 in rear or 18x8<br> <br> or would you rather go for the reco, of<br> 255/35YR18 on the 18x9 in rear ? Why ? is 235 to narrow for 9' ?<br> <br> I am not looking for that out of the fender look,<br> is the offset of the 9 inch making the wheel go<br> in that direction or is it widening more to the<br> center of car.<br> <br> I think my SLK has the AMG 170 8,5 in front and the 9,5 in rear and the wheel and rear is a bit outside of carbody = probably not nice to lower into that.<br> <p>
