I have Eibach pro-kit springs on a '95 c280 and was wondering if it would fit a '95 c220<br>
<br>
thanks<br>
<br>
harold
I will disagree with Luke on the fitment of C280 Eibach springs on to a C220. Eibach list seperate part numbers for these two cars first off, the engine size and weight is the obvious reason for this. I would not recommend try to swap these two kits, but who am I? Good luck.<br> <br> Tony Downs<br> [email protected]
oops !
Tony,<br> You are correct! The physical installation will work but, the spring rate for the 280 is slightly higher than the rate for the 220. Thanks, for noticing I don't know what I was thinking (er not thinking)<br> Luke
