Outstanding Contributor Always Remembered RIP
I have a stripped thread on a rear lug bolt hole ,,, was thinking about coiling it but on second thoughts I was thinking. I could weld a nut on the rear of the stub axle. If I put a bolt in the hole with a nut either side and tightened it up, that would keep the nut tight to the back of the stub axle while tacking the nut on.
What do you think please
Safest thing in my opinion would be to redrill, and re-tap the stripped out one to the next size up. Then install a double sided stud. You can safely mount the stud in the hub with loctite, and then use the correct lug nut for your style of wheel.
You may have a problem finding a lug nut with the proper contact shape. Welding a nut on the back may be a problem due to clearances inside the hub assembly. It may destroy the parking brake as the hub rotates. I would vote for the Heli-coil but it must be done precisely.
