1 - 17 of 17 Posts
1984 380sl, 1988 300ce, 1988 420sel (gone)
The tilt mechanism on my 88 420sel tilts completely on the drivers side and only partially on the the passenger side. Initially it barely moved but it has started to move a little more since I started using this feature. Is there an easy way to lubricate this feature? Did the sunroof tracks this weekend and the the roof glides much easier now. Just got to get that tilt mechanism to work.
Also the wind deflector won't pop up. I manually have to lift and lower it. Any hints on how to fix that.
1991 420sel
The deflector is probably stuck and needs lubrication. Squirt some silicone spray lube in all the pivot points and see if you can get it to go up and down. My advice is NEVER use the tilt feature. Using the tilt feature greatly increases the chance that you will have to learn how to dismantle the sunroof and replace very expensive parts. Be happy with a sunroof that opens, and perhaps more improtantly, closes. Also, in cold weather, do not use the sunroof. Charlie
· CH4S Admin , Outstanding Contributor
1985 500SEC, 1991 190E 2.6.
Have you tried 'search this forum?'
MB slide paste = P/N - 001 989 14 51
benzwag said:
My advice is NEVER use the tilt feature. Using the tilt feature greatly increases the chance that you will have to learn how to dismantle the sunroof and replace very expensive parts. Charlie
Should have listened to you Charlie. I dropped the tilt and and tried to open the roof and something broke/jammed. :( The good news is at least the roof is in the closed position.
300SD
I must say there is one good thing about the sunroofs in my MB cars. They do not have the tilt feature and both work very well.
Of course, the sunroofs on my 98 Nissan Maxima and 99 Mazda 626 never gave me any trouble and they have sliding and tilt features. Maybe I have good luck with sunroofs. I owned plenty of vehicles with factory sunroofs and never had any problems with any of them.
1990 SEC
I use my sunroof all the time, especially the tilt funtion. :)
It works well, you get efficient air circulation without the wind buffeting of an open sunroof.
Lubricate the sunroof slides, unclog the drains and you should be fine.
I've only had to re-set the gears for the sunroof (in trunk) once.
1990 560 SEL with Euro engine, 1998 SL500 Sport
Is slicone spray lubricant used on the sunroof rails as well? I was thinking of using dry PTFE spray lubricant on my sunroof. It closes very slowly and also seems to stall a bit or get hung up. I have to drepress the sunroof switch in quick bursts so it will close.
2000 e320 4matic
Jonathan will sell you a small amount of the MB approved sunroof paste for a few dollars. Shoot him an email.
560SEL
Since its on topic:
I fixed my sunroof a few weeks ago after the slide/lift arms had broken. Now when I push the close button all the way the sunroof closes but at the end tilts up. The tilt button isn't functioning either.
1990 SEC
pathogen said:
Since its on topic:
You need to re-set the gears behind the access panel in the trunk.
Do a search on the subject.
If you can't find the instructions, I think I have a write-up on my home computer.
560SEL
I ended up messing around with the nob for a good half an hour before realizing that clicking it out twice did nothing because the knob wouldn't budge at all. Turning it after the first click didn't seem like it was doing anything and I couldn't figure out how to allign the knob with the allen wrench and my head started to hurt. So to see how things were going I asked my gf to push the button to see it it worked.
It went backwards just fine but when she tried to close it seemed like it was losing power and just stopped halfway open. At this point I got super pissed off and thought I had spent those 8 hours figuring out how to replace the gears was for nothing.
Then I realized that I could calibrate the knob and ended up doing a trial and error to get it perfectly alligned.
Thanks for the help!
1990 SEC
I'm glad you figured it out.
It all seems a bit inexplicable at first, and it is also difficult to descrive exactly what you need to do without pictures.
1 - 17 of 17 Posts
