1 - 12 of 12 Posts
1998 E-320
Have a 1998 E-320 with 145,000 miles I'm putting on new brake bads. I'll clean up the calipers and use again. I'll push out the pistons (not all the way out, of course) and blow out under the boots with compressed air (about at 50 PSI). But what should I lubricate the pistons before I push them back in (using a c clamp)???
Do I just squirt brake fluid in side the rubber boots? Or will the brake fluid degrade the rubber boots. I will push the pistons in and out a few times before I reinstall. Any thoughts on the fluid to lubricate the pistons?
Blowing compressed air on the cylinder boots brings risk of pushing dust under them, so I would not do that.
If you see mud or dust on the boots, I would clean it gentle with soft brush and that is it.
Opening the boots if you don't have a problem is a good way to start one.
'01-E320 & 02-ST2
Plus 2,267.
If the boots are fine, leave them alone.
A cheap nylon-bristled paintbrush (1/2" or 1" at most) is great for cleaning them up. If you need a little more stiffness, trim the bristles shorter.
Good luck.
I never hear about anybody promoting rubber conditioners, but I am using Formula303 for extending the life and beauty of my tires and I would advise to spray some of that stuff on the boots as well.
'04 G55 '80 280GE '99 S420 '98 E320 2011 E350 2016 GLA250
I wouldn't Monkey, at all, with any of it...
If the Piston Rubber "Boots" are INTACT, Just Press back the Cylinders, and Call it a Day...
1998 E-320
Discussion Starter · #8 ·
Big development. I tried the PB Blaster with a Mapp Gas (plumbing) torch again on the bleeder screw. Heat and re-applied the PB Blaster a few times. Then used a small vice grip on what's left of the bleeder screw. It let loose, fluid came out. So I bought a new bleeder screw and bled the drivers side front caliper for the first time since I owned the car (2008). Bled it till new fluid appeared. Now the caliper piston goes out and fully retracts back. Like it should. So that takes care of that.
2001 C320 W203
I am considering to use the can compressed air to blow out the piston for the caliper rebuild. Anyone tried the can air like this before?
I checked the air pressure with the gague. It reads 40 psi. Should be enough to blow out the piston?
2005 CLK55 AMG Coupe ,CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Rubber grease is also fine to use on both seals and the piston sides,but obviously don't put any inside the caliper chamber.The inner seal will prevent rubber grease entering the brake fluid area.
Piston should come out with around 15 psi,you can even use a sport/bicycle pump with appropriate fittings/nozzle to force the piston out.
1 - 12 of 12 Posts
