1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL, 2003 SLK320
I saw a DIY procedure with pix of the procedure to lube the single wiper arm on our cars. I looked in the DIY section and couldn't find it. Did I see it here or does anyone know where that article is?
Thanks.
Len
Discussion Starter #2
You'll find that your wiper mechanism differs slightly from the pictures, but not in any way that matters.
Missing from that article is the suggestion to remove all of the existing grease. You should not mix greases with different bases, and I have no idea what base is used by the factory. If you get the correct grease from M-B, this won't be necessary.
