1985 500SEL
what kind of lube service (if any) should be done with an oil change??
My mechanic told me that there were no grease fittings what so ever on these cars, is that true..
also what can I use to lubricate the door hinges , I know there is a special lubricant for the sunroof that you can buy from benz..
Depends on the day!
Just check the fluids and filters.. Do the trans every 15-20K. Nope, no grease fittings.
I lube the Whole throttle linkage 2X a year.
Nothing that i've found. If they are making noise you need a new door check.
Jonathan
