it's probably more an age issue than a model issue. Other makes' web forums probably see the same thing. Without having the actual numbers on problems per model year we can only go by what we read and see on the various sites. Also, as models become older and thus cheaper, ownership is typically transfered to younger individuals. And most likely the young are more computer and internet savvy and you see them here on a more regular basis than the older set. I'd have to have the numbers on that as well as the actual % of ML owners who even bother to post on this ML forum. Without that we are just making assumptions that may or may not be true. I guess they are generalizations!asianml said:Not much to report with the 02. Been running real smooth. :eclipsee_steering:
350insp said:Yeh, probably because it is cheap and has the big star on the grill. Then they found out the issues and scream.![]()
Yeah, ...because this forum is for W163, and this will cover all MLs from 1998-2005. And now is 2007.... 2 years after W163 was re-designed!...C-Rod said:Or has this forum just become a forum for 98 and 99 ML's...lt seems like quite a few people are picking up some pretty cheap 98 and 99's...Good luck with them..
I think what he's saying is....there aren't the same number of "newer" W163s joining.wannaln said:Yeah, ...because this forum is for W163, and this will cover all MLs from 1998-2005. And now is 2007.... 2 years after W163 was re-designed!...
There won't be new stuff here for W163... in my opinion... For new stuff you would need to jump to W164 forum... or trade your W163 for W164 and kiss this forum good bye!...
