1 - 8 of 8 Posts
G
I have a 2000 320 and I have installed H&R Springs. I think it looks better but i still want to lower it 1/4' to 3/4' more. I've heard people talking about 'spring pads' but I know nothing about them and what is currently on my car. Can anyone help me achieve my goal? Also, if you change these pads, does it make the ride harsher? Thanks.
G
Discussion Starter · #2 ·
The pads go on top of the spring and alter lowering a bit. The stock ones are 3 pt and 4pt rear.
G
Most people uses pad # 1 all around when lower their car. If you still use stock pads then....
<br> your's car is not being lower that much. In Mercedes car, the pads is use to determine the ride hieght of the car.
G
Re: Most people uses pad # 1 all around when lower their car. If you still use stock pads then....
if i got H&R's and #1 pad all around would it make my ride harsher?
G
Discussion Starter · #6 ·
How difficult a procedure is it for the installer? He is good but charges a lot for installation.
1 - 8 of 8 Posts
