The links need to drop to lower the vehicle. On the rear you can lower the link by bending the lower brackets down with pliers or a crescent wrench, you can bend the bracket until it's nearly touching the a-arm but when driving you'll bounce off the bump stops, bend them back up for a better ride. The ML63 is already lower than other models. I like my ML63 level, not raked. So I first lowered the rear then raised it to a comfortable ride, and I didn't have to lower the front. But to do so you space the bracket from the a-arm with a couple of washers and a longer 10mm bolt.
How low can this method lower a ML W166?
· Coupe/Convertible Forums Moderator
CURRENT: 2011 SL550 FORMER: C300, ML350, CLK550 Cabriolet, C240, ML320, 300TD
Welcome to the forum @gtrandrew - please take a moment to read the information on the links below. It explains how to use the forums and update your user profile so that your car's details and your location appear on each post below your avatar. This is good information for others to know when trying to help. It also has good information about how the forums are organized and how to use the search feature:
Find your Forum Section, Navigate & Search
Complete your profile.
You originally posted this as a reply to a thread in the W164 forum. I have moved this to the W166 forum so hopefully you will get help for your specific vehicle.
