1 - 16 of 16 Posts
Banned
I found a company that offers an adjustable link that lowers the ride height. Wanted to know what if others tried and how the ride is. Thanks
Banned
Thanks to John at Adjustable Air Ride I got my delivery within 2 days of order and they look geat! Installation instructions are spot on and I'm plugging in my camera to ensure I have clear pics. I'm looking forward to this. Shouldn't take more than 1hr & 1/2. Hardest part will be photos.
The links need to drop to lower the vehicle.
On the rear you can lower the link by bending the lower brackets down with pliers or a crescent wrench, you can bend the bracket until it's nearly touching the a-arm but when driving you'll bounce off the bump stops, bend them back up for a better ride.
The ML63 is already lower than other models. I like my ML63 level, not raked. So I first lowered the rear then raised it to a comfortable ride, and I didn't have to lower the front. But to do so you space the bracket from the a-arm with a couple of washers and a longer 10mm bolt.
Banned
I get where your going but I like the idea of having a stronger, billet aluminum adjustable arms.
Finally got my sons rear end mod done in his JZX. Finished my wifes Tahoe brake job so it's my turn! Got the camera loaded so now I'm doing pads, rotors and the Airmatic adjustable arms to lower. Can't wait!!!!
Banned
I'm being very patient. This is an all in one job. I 'm doing rotors and pads and had to send the f**king rotors back. All the adjusters are on and I have pics waiting to set the car on the ground and finish this.
Stay tuned sports fans.
Banned
Finished with the brakes set the car down and biiiiig grins :D . It works!!! and the great part is its fully adjustable so if want level, rake, almost oem, Boom!
Thanks a pant load to John at adjustableairride.com You D man!
I highly recommend this to anybody thinking about those fancy ECU type air ride controller B.S. This was so easy my wife could have done it. By the way she still likes how the ML rides apres' lower. She digs that its easier to climb in to. She has back problems.
So doing some of Santa's work but should be able to post pics tonite :cool:
Banned
I'm trying this on a camera I've never downloaded so here goes. Our weather here is freezing and the cars dirty but this is good teaser.
Both of the last 2 pics are at comfort level which is slightly higher and will automatically drop with the dash switch
This is the lowered height shot after readjusting the arms
I just ordered a set of these as well.
How much did you lower it?
How does it feel in sport mode when the aromatic lowers it another 15mm?
Nice job!
How does it feel in sport mode when the airmatic lowers it another 15mm?
Nice job!
Banned
Discussion Starter #11
I dropped it 3" and then came back up to 2 1/4" up front and 2 3/4" rear.
You can feel the noticeable sport setting, it's not harsh but does feel more precise. It's hard to put into words so I'll just say compared to stock; in sport lowered, you get better feel and is a lot more comfortable than say an H&R lowering coil spring. It's still an SUV and isn't going to out handle a SLR but it's lower and tighter.
Banned
Discussion Starter #13
Hi, welcome to the W164 forum. Put your general area and car in your user sign on. Others can reply to your posts without the confusion, much faster being able to reply to a more tailored thread; it's good practice to put your car (350,500, 550 bluetec) and your general area in your sign on.
Go back and click on the Airride icon. It gives all the details.
A word of warning with these links, particuarly if you live in a cold climate as Ive just found out.....with road salt and general wetness getting in, the joints corrode over time and eventually sieze or snap.
Mine were on for a year and a half or so before this happened yesterday and one of the airbags popped taking out a sensor with it.
Speaking with the tech this morning hes told me that the joint seized and the pin just rotated freely within the arm meaning the system didnt know how high the car was forcing excess pressure in blowing the bag.
Not cheap to sort and not a mod I'll be doing again in a hurry.:surrender:
Banned
Discussion Starter #15
This shouldn't have happened. The cup is a synthetic (Delrin) and the ball is stainless with a galvanized arm. Rust isn't possible. Something else happened to the joint to cause this. Your situation was unfortunate but The socket or cup on the adjustable arm is made OEM protective and use the MB ball pins. The socket even has a soft protective boot covering the joint. Something else happened causing a fail.
Do you have any pictures of the rods or cup failure you could share?
Wonder which links Aeroresh had. There's another UK firm which is offering basically all-thread rods with joint ends for less money - and you know how that works out.
The aluminum ones - I just don't see how it caused a problem. But still something to keep in mind.
1 - 16 of 16 Posts
