1 - 8 of 8 Posts
C230 SC KOMPRESSOR
It's fairly easy to do just dont forget to rent a spring compressor. and i'm happy with the way my H&R's handle and ride.[;)] good luck!
2002 C230k
A regular spring compressor doesn't fit right and can be dangerous to use. I think the correct spring compressor is made by Klann.
My Benz: 04 S430
I've acually done my front and rears without usung a spring compressor. You need a floor jack, and a little mechanical skill, you can carefully remove the spring from the strut without taking the whole thing out and dealing with a compressor. I've done thins about 4 times now, and it takes me about 30minutes to change a front spring.
C220 CDI T A & A200 CDI A
Lynn - 2/21/2005 10:42 AM
But you CAN do the work with it. Be careful, and know the risks. That's how I did the work. You can borrow them from O'Reilly Autoparts.
1 - 8 of 8 Posts
