2006 500SE, 1972 280SE
My SO, aka "the destroyer of Benzes" (wrecked my last 500SEL), has managed to rip out the plastic panel on the passenger side door by catching it on a high curb and pulling on the door. The panel is still held to the door from the upper attachments but is flapping like a doggie-door because nothing holds onto it at the bottom. What parts do I need to repair this? It seems like plastic holding pins were broken in the process...
'98 C43 Kombi daily. '94 C280 factory manual track/drift slag.
Ha snap! Except I pulled mine clean off, and didn't realise 'till I got home!
Mine just popped back on, but it had the earlier crinkled panels. I know the later smooth ones are a bugger to get back on as the little platic clips just snap. Easy enough to replace though.
I have the later "smooth" panels (the ones colored the same as my paint and without the ribbed pattern)... It seems like there's a white plastic screw/retaining clip thing involved and that has broken clean off.
I suppose the dealership's probably a good place to get a replacement. How do I remove the panel to replace the broken pieces?
