Check this out, right after R/Ring rear subframe bushings, on the tired test drive to enjoy the reward of my labour.... there goes the front end...
I'm pretty sure the train tracks, which were reminiscent of a jump for Super Dave Osborne, bent the left LCA, then jacking the other side up today the weld cracked for good as the weight transferred (very bad noise that scared the daylights out of me). Pulled 20 degrees to the left after the initial hit but drove okay to lab and back today despite a underlying bad feeling.
The left side shifted so that the knuckle has moved relative to the shock... I am wondering if you all think I can get away with new control arms both sides, new ball joints, and a standard alignment, or if the subframe is knocked out of wack now and requires more... car is a 1996 E320, here are the pics of the right vs left side...
(close up with light is damaged left side)
Let me know what you think, really hoping I will not regret keeping the old girl alive after this one.. but concerned about restoring geometry. Any tips or advice would be awesome, not experienced at all RE: getting alignments as my past vehicles I've been too broke (student) to bother unless tie rod related. Also any good threads/tips you have saved regarding LCA R/R and front suspension refreshing in general would be great.
As well, I think I am going to grind off the sealant on the perches and run welds around them too. Anyone done this before, or reenforced them in general?
Thanks, and check your W210 control arms!
