2005 E 320 CDI
Enthusiasts-my 2005 cdi with 321000 has a SLIGHT separation or tear in the bushings of the lower control arm (part#2110376). They were replaced at 260180 in June of 2016. My question is, how big of a separation or tear is acceptable before replacement is necessary. These separations are about one inch or so and I don't think go all the way through the bushing. The ball joints were replaced at 201000 and I think are ok but if I replace the bushings, I'd do the ball joints and sway bar links which are original. Thoughts? steve
CLK 430, E500 4 Matic Wagon
You had me at tear...not sure what part of this wonderful world your located, but replace is best especially when the cold/winter is here. That tear is like a tendon in the knee, and when that "tear" spreads..rubbing/grinding on metal. So I Recommend replacing.
Just my opinion.
GL
2006 cdi, 1993 500e
The inner bushing is the weak link on the LCA. You can just replace the bushing, it is important to have the suspension pre-loaded with the car weigh or you will pre-load the bushing and get early failure.
