1978 450SLC (6cyl)
Hello, I have a 2009 CLS550 with 57,000 miles. My wife took the car out a week ago and filled the tank with a lower octane gas than the premium I normally put into it. It was Unleaded Plus so the octane rating was 88. Now the car is idling and riding a little rough. I tried to drain the tank but could only get it down to about a half tank. I then took it and filled the rest with premium gas. It has gotten a little bit better but still sputters when idling or when I press the accelerator. Since I don't drive it much it would normally take weeks for the tank to need to be filled again.
Does anyone have any ideas on what I can do to try and fix this before I have to take it to the dealership? Again, it isn't terrible or kill the engine but it is noticeable.
· Coupe/Convertible Forums Moderator
CURRENT: 2011 SL550 FORMER: C300, ML350, CLK550 Cabriolet, C240, ML320, 300TD
I seriously doubt the issue is with the fuel octane rating. I've occasionally run 87 octane in my CLK550 and SL550 (same engine as your CL550) with no issues. I actually had an ML320 with an M112 engine where I ran 87 octane in the summer because of a defect in its TCU code that failed to adjust for the higher oxygen "summer mix" fuel causing it to backfire and die.
00' E320, 03' E320T, 05' C230K
On my low mileage car, I use Stabil Storage in the gas. I will also put in Chevon Techron Concentrate in about once a year.
