2005 CLK55 AMG Coupe ,CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
There is no need to code anything.
Be certain that the bulb is the correct type and is good and fitted correctly.
Also check the wires in that area for any damage, sometimes the insulation degrades due to heat.
You could try swapping the bulbs from side to side ,,
if it still doesn't work ,
you will need to test for power and /or have an auto electrician check it out.
