I’m having problem with my low beam I thought it was a wire harness problem so i isolated each wire covered with tape and the problem still, I bought a new headlight assembly and the low beam still not working!
I tested on the right side and the headlights work properly,I bought a fuse tester and the fuse 62/63 for the low beams are good, I don’t know what else to do, I took it to a mechanic and this guy sent me a picture of another headlight assembly, saying that the wire harness are bad and need a new headlights assembly, and charges me $400 for labor and $230 for the light assembly, I told him I have a new headlight assembly and the problem is not the wire harness because the new headlights works good but the low beam , I can’t drive my car till I get it fix because I had 3 warnings already by the cops and I don’t wanna get a ticket, please any advice would help , taking to the mechanic should be the best option , I can’t go to work, and Uber is killing my pocket, I’m depressed and frustrated at some point thought to sell my car please any help will be appreciated
Thank you
2008 AMG CLK63 Conv., 2012 R350 4-Matic, Wife's 2015 C300 sedan
Year and model please.
Purple Moderator
I would first check to see if you have power to that socket for the low beam using a test light a multimeter.
If there is no power then the SAM that holds the fuse holds the fuse may need to be checked.
