Hi People !!!
I need some help. I just got the Left Low Beam malfunction error message...Can someone please give me information on how to replace the bulb on my car.
1) Product name, number and Price ( Cheapest !!! )
2) Procedures to follow
Thank you again for your help:confused:
W209 CLK500 & W220 S430
First you'll need to pop open the hood . . .
Have you ever done that before ?
Cause ~ I'm just askin' ?
Red, *<:){)-
94 E320 Sportline sedan 86 190E 2.3 16V sedan 04 S430 Sport
Well first do you have standard halogen bulbs or bi-xenon?
Your owners manual also covers how to change a bulb as well, it is a very simple process.
And the saying goes, you get what you pay for so "cheapest" is not always the best.
· W221 & Audio Moderator
2015 S550
Hi, Pratt. Your car came standard with halogen bulbs, and had an upgrade to xenon (which is different from Bi-Xenon). The Xenon upgrade would have a Xenon low beam and a halogen high beam. It is also possible that a prior owner (if there was one) installed a Bi-Xenon kit.
The owner's manual does discuss how to change the bulbs; one easy way to see what you have is to pull the old bulb out. Your manual will also give the bulb German designation; you may have to check for a Canadian equivalent.
When you replace one, you may find you want to change the other as well; the color of newer bulbs often does not match the color of the old, even if both have the same "color temperature" rating.
