1991 560 SEC
sounds like from the rear wheel, specifically the right. it does it when going down the highway and when turning left. the car does need rear brakes and rotors. would this cause the sound? thanks for the help
Moderator
Mercedes
Sounds more like wheel bearings to me. I would do the wheel bearings at the same time you do the rotors and brake pads.
MB 420SEL 1986-Bought in 2010, MERCURY VELLAGER-1995, NISSAN MAXIMA 1996, Buick Lesabre 1995
It could be brake, rotors, bearings etc. Very simple to test. Jack up the rear of the car and turn the wheel by hand few times also remove the calipars and turn the wheel again by hand. This should give you the correct diagnosis. You might also need to wiggle the wheel back and forth while holding the wheel up and down and front and back respectively. Do not forget to check parking brake shoe pads- most common cause of humming noise from the rear wheel.
Sahai
