1 - 14 of 14 Posts
Outstanding Contributor
450slc5.0cab 280sl5sp 280se4.5 500se+500slAMG +250seStkW108 350sl4spdX3 500secEuro
6 of one, half a dozen of the other (assuming your existing tie rod couplers are fine)?
Tie rods are faster and easier than messing around with replacing just the ends?
I deferred them in my latest order because AutohausAZ only had the ends.
No responders = "Son, you are lost in the minutia. Get them done and move on."
Is there a question is here somewhere?
R/C107 Moderator
Yes. He is questioning his sanity. I don't have the answer.
As for the ends vs. the unit? If you can't get one do the other.
And I'll paint the old rod middles to make them look new... if just buying the ends. Next round at AutohausAZ I guess. My sanity is lost. Learning a lot though. Thanks fellas.
It Is What It Is, Dude
Installers love the complete assemblies, particularly if they're working on book time. If you supply the bits and the installer is on a clock, you'll pay to assemble the rods.
If you're doing your own and the time is 'free'.....
560SL,380SL
Well, you would think if one end was bad, the other one would be going...but I've only seen outer tie rod ends go bad so far.
Same.
I was lost in the minutia. It never even crossed my mind that someone would only replace the outer rod ends. I guess here could be situations where the inners are hard to remove and just replacing the outers could save tie. Huhm.
Thanks for the insight. Now to just replace them.
1975 450SL
When I had my subframe done, I got the entire unit. I think the price difference was about $5.00 total between the units and the ends separately. Since the car had been in a front end accident, and there were some scrapes on one of the rods, I decided to go the whole boat.
Luckily, the dealership would install my parts when they did the subframe changeout. Mine was failing, there was a good crack in the drivers' side, lower arm, rear bracket, so the procedure was to change out the whole subframe. I think that me supplying the new parts may have made it easier for the mechanic, since he didn't have to hassle with preserving the old ones and transferring them.
I explained that I ws going to replace the motor mounts, subframe bushings, and control arm bushings myself, but after investigating the need for the super-heavy duty spring compressor, I decided to ask them if they would be able to do it with the subframe recall. They were happy to do it.
Scott
.... and control arm bushings myself, but after investigating the need for the super-heavy duty spring compressor
Well I proved this not to be the case. But an extra pair of hands was needed.
1975 450SL
I didn't have the extra set of hands available at short notice. I had an opportunity to get the whole thing done at once, so I jumped at it.
Just my experience & situation.
Scott
I would have done the same.
Removing springs is not my idea of fun.
1 - 14 of 14 Posts
