Loose Turnsignal Stalk on 2001 S500
4.7K views 7 replies 4 participants last post by  W220HI
I know this is an older posting, but I had this problem and found the problem to be quite simple to fix. There is a small access hole located on the lower portion of the steering column shroud. Using a 4mm allen key, I tighted it down and no problems!! This was on a 2000 S500. I could not get a good picture, but sniffing around google, I found the following video:
If you forward to 0:52, you can see what I'm talking about. Note that the steering wheel does not need to be removed to access this.
I hope this helps someone in their future searches!!
