I have 1995 mercedes s420, i want to get lowering springs im just not sure if my car is self leveling or not
Moderator
1995 Mercedes S420, 1995 SL320, 2000 Land Rover Discovery II, 1985 Lotus Turbo Esprit
If you have a 420 then it's highly unlikely to have the hydraulic suspension unless it was a special order. Do you have a switch on your dash that looks like a little shock absorber? If not, then you have the standard suspension.
'82 500sec euro, '95 Ford F150
The rear most likely has self leveling suspension, but the front does not. H&R sells the correct springs. Be prepared that you may have to “play” with different thickness spring pads in the front to dial in the spot on ride height.
Are you doing the work yourself?
W140 Moderator
"CHRIS" Merc 92 600SEL / Sold > 93 600SE / 93 S500 / 89 560SEL / 413CDI / B180-CDI /A170-CDI
Open the hood & see underneath the cover you see in pic attached . If the Reservoir for Hydraulic oil is there ,you got SLS Suspension if not ,normal Struts . Pic provided by ISS.
2nd , On a car with SLS suspension , you only need to Lower the front since the back has an adjustable Lever for Higher & Lower .
2640288
