Serndipity, you are good. Thank you so much for all your feed back and support for my search of W208. I greatly appreciate the time you put in reply to my post. Thank you.
I have 2009 W211 (sport package OK, but I don't like stagger wheels), 2007 W221 S-550 (What a boat, love the comfort, but its feel like boat), and got 2011 G-550 (Crazy bouncy off road truck driven in the city and freeways, feel bad for environment 12-14 MPG), but still love and enjoy driving my W210's. I don't know, may be I am crazy about the classic styling of W210's.
When I test drove many W208 convertible cars while searching for the good car, I have noticed that I feel like W208 Convertible, kind of little bouncy or slightly shaky and not quite good stable due to may be there is no solid roof and no pillars (A, B, C and D) that given me this slightly un-solidness feelings in convertible W208. For some reason I know W208 don't feel solid stable like W210, I think it is due to convertible soft top and no pillars.
Also, when I went under the W208, I have noticed that there are 2 cross members run from middle side bottom of car to front center, probably these are for giving support for stabilization of convertible car?? I probably need to check those to make sure they are good to get ride of slight shakiness.
The shakiness or not feeling solid is not kind of the one you get from engine mounts when they go bad, it is different kind of feeling. Like I said it is due to convertible soft top probably.
Anyhow, I believe I have found my W208 convertible, you will see me more on W208 forum now. I am making deal to purchase this 2003 CLK-320 convertible with 119600 miles on it. The Car Fax is clean, the exterior body is clean including the soft top, interior is clean, under the hood is clean, except there is small sipping of oil between back of engine and front of transmission (Common on high mileage W210's, I got on my 2001 E-320 same, little leak is ok, don't want to spend $$$ for the engine/trans seal) convertible top will need some service, it is working right now, but I have noticed 1 or 2 times some hesitant in open and closing, moving slow, like you said, it may be cables and lift cylinders. Or relief valve screw need to turn 2 times clockwise to get all the system pressure in the system. I physically check all the cylinder with flash light and touch where ever I can get access, I did not see any hydraulic oil leak evidence, but I did not remove the carpets.
One item to note that when I was in trunk of car, I can see this relief valve screw cut in carpet, but I could not see full cut for Hydraulic oil reservoir to check the level in the carpet. The cut for reservoir level is not open in carpet. The seller don't wanted me to cut the bottom part of the reservoir level part of the carpet to see the level of hydraulic oil in the tank.
I will post here some photos as soon as I get 2003 CLK-320 convertible in my drive way.
Thank you all for your feed back.
