1 - 11 of 11 Posts
2003 ML500
Anyone know a good subwoofer location in ML with 3rd row to preserve maximum cargo space? I need the 3rd row and cargo space as I constantly doing road trip with families.
I seem one from previous post where a sets of speaker is build into the rear hatch to the opening for First Aids kits and Tool kits but would there be enough space there to woofer to works freely?
98ML320
I had one 10" rockford installed inside the space where the CD player used to be. It's a sealed enclosure with about 1.25 cu ft air space. The original cover still fits over and is completely stealth. Great balanced sound (my shirt still trembles on strong bass notes) but the neighborhood is not waking up when I drive by. This was combined with good mid-bass drivers in the doors.
Works well for me cause I always pack the truck full of stuff. The other benefit is that I can reach the CD player from the drivers seat.
I've also heard you can put 2 x 8" drivers into the tailgate and seen one install. Less stealth but might give you some additional air movement.
ML430
I have seen people do almost the same thing. http://www.sounddomain.com/memberpage/490508/2
If you want to ask him how he did it, he is in * forums and his name ls 55frantic. But all it is is a Fiberglass overlay that takes the space of the existing side panel.
2000 ML430, 2008 GL550, 2008 Ford F250 Superduty
just curious, is a capacitor needed to run a 10" system? i heard the ml's have a pretty heavy duty alternator and it isnt. just wanna know if im gonna need one.
98ML320
My sub installation is built in below the OEM panel rather than a replacement overlay. Much cleaner install, and you can't tell it's modified at all. Course there's not enough air space for a 12" so you would have to stick out to accomodate that. My installtion was all about cargo space, convenience, tight deep bass and stealth. Others will choose differently
I always hated having to take out a sub box everytime I haul something.(been there done that..) Where to put it while your moving things. You aren't always near the garage when you have to use the trunk sometimes your just out, then what..... Besides we don't have garages here in THE city.
In any case, the point of the original question was how to put the sub in and accomodate the 3rd row simultaneously. And to address the original question, there is enough space in the side compartment if you choose the right sub. Some are designed to need less air space and perhaps one designed for a small and ported enclosure could need even less space allowing for a larger driver. I did mine in 98 when I first bought the car so I'm sure there are new ones out now. You should really consider a skilled install technician to help you design and install it properly.
I think I also looked into one that fits where the BOSE sub sits under the drivers seat. You could consider 2 smaller subs under the 2 front seats which being closer to you will sound very loud also.
1999 ML 430
I have the same problem as you, I'm going to put a 1 10 behind the seats, plenty of room 12" and the depth of the box is only around 9" and it is on an angle so when the back seat is up it doesnt hit the box, easiest way to do it
04G55AMG,08R320CDI
tsanjose - 1/28/2005 3:19 PM
Don’t really need one for a 10" but….. I’ve got 1000W Peak (300RMS) to the sub 12�. 1500W (400RMS) to the speakers. Thought a couple of caps would be cheap insurance against the possibility of alternator stress.
2003 ML500
Discussion Starter · #10 ·
This is the freshiest Idea I seen so far. Looks very mobile as I can remove it for hauling stuff, that is if I know it before hands.
1 - 11 of 11 Posts
