1 - 20 of 20 Posts
1987 Euro 500SEC & 1988 Euro R107 420SL
Hello Benz World Members
I am looking for R107 Air Condition complete part set including the center ac control panel switch. A brand new parts or a working used AC parts. My R107 is 1988 420SL Right Hand Drive UK Version that came without Air Condition.
(note: I did contacted SL Shop UK but they don't have it in stock)
I really appreciate any information about where to buy the AC set.
Thank you
Thank you
It looks like noting is crossing to the 560SL, so you will probably be best if you can find a UK hosted sight.
Hello Roncallo
Honestly I don't know how the AC version of this car suppose to be. The car is in the process of restoration. When I bought it, the car had been parked for 2 to 3 years
The Center panel pic is like this, only heater I think:
2650758
Engine bay pic
2650759
Thank you
1979 450SL UK spec
I can only suggest looking for someone breaking a car and try to salvage the parts, however this will be a big ask of the breaker and the builder.
R/C107 Moderator
If the UK only had the early version you're lucky. Less to go wrong.
Hello Race Diagnostics
Do you know anyone that might have it?
1979 450SL UK spec
No, I think it will be a case of waiting for the correct breaker car on ebay etc.
I have a couple of numbers you can try, I will PM them to you, one guy who breaks 107s and another that rebuilds them.
Hello Roncallo
Engine bay pic
Thank you
Looks like the AC lines will probably be coming out on the right side of the engine compartment. That would put the US parts out of the question.
1973 450 sl
Hello Roncallo
Engine bay pic
Thank you
you don;t want to take the dash out of an sl you;ll hate
1986 560SL
At the very least, the evaporator assembly would likely be totally different from a LHD, U.S. car. If you don't care about the AC being all original, a modern variable swash plate compressor, with a simple expansion orifice, using R134a would give the best cooling performance. That type of system relies on pressure sensors and a control module.
1973 450 sl
i"v got several syxtems took out completely from my 73 have 80 system still in parts car
Discussion Starter #18
Hello Hertzy
I think the workshop will hate it later on when I can find the AC to be install .. :)
Discussion Starter #19
Hello Turbo510
If I can not find the original AC set for this car then I will take that route to install aftermarket AC
Thank you
As promised, here is a list of all the major parts you will need and the cars they are used on. One word of caution: Just because a part number is used on a certain model does not mean it is used on all cars of that model. But I think if you get parts from a 1986 to 1989 RHD 500SL with manual air you will be pretty safe.
Also for some reason I could not find the controls or the compressor for the 420SL in EPC.
2651310
1 - 20 of 20 Posts
