1 - 20 of 20 Posts
1984 380SL
Hello guys..
I need to change a few things on my 84 380SL and need your help finding stuff..
So i need a full engine overhaul kit to change all the bushings and what not. I also need to get a full exhaust system as it is a little rusty and needs attention ASAP.
Any idea where those can be found?
R/C107 Moderator
Hello guys..
I don't know of any bushings in the engine. Why does the engine need rebuilding?
As for exhaust try a search. I am sure you will find threads with suppliers mentioned.
1984 380SL
Not the bushes in the engine, its called an overhaul kit because it comes with all bushes, seals...etc
'71 250, '78 450SLC 5.0, '78 450SL, '81 380SLC 5.6, '89 260E, '15 Kia Sorento
I saw the bushings and the exhaust system for my cars on AutohausAZ.com. They will likely have yours as well. Also, I had a local muffler shop replace my muffler and tail pipe from the resonator back, with a dual chrome tip for around $200. They could have done the whole system, but I didn't need it.
R/C107 Moderator
I know what an engine overhaul kit is. Are you referring to some other system?
1984 500SL 000760
Does he mean to be saying bearings instead of bushings, or maybe he needs a suspension kit with new bushings in addition to the Engine rebuild? I thnk we need clearification.
1984 380SL
Sorry for the confusion guys, i am very illiterate when it comes to these things. My mechanic told me we need to look for an Engine overhaul kit so i thought id tap into your expertise and get help on where to find it :)
1984 500SL 000760
Makes > 1984 Mercedes > 380SL > Engine Parts, Seals & Gaskets > Main Bearing Set
Part Number Brand / Description / Restrictions List Core Your Price Qty Select
1160300140
Glyco
Main Bearing Set; 1st Oversize (+0.25mm) 63.75mm
Special order item - limited availability. $380.00 $128.15
$134.89
SALE
1160300040
Glyco
Main Bearing Set; Standard 64.00mm
$220.00 $111.96
$117.85
SALE
Autohausaz.com
1984 500SL 000760
Makes > 1984 Mercedes > 380SL > Engine Parts, Seals & Gaskets > Piston Ring Set
0010307924
Goetze OEM
Piston Ring Set; Standard 88.00mm - 1.5 x 2.0 x 3.5mm
1 per cylinder, requires 8 sets per engine. $155.00 $41.14
$43.30
SALE
1972 280CE
R/C107 Moderator
As far as I know there is no complete kit for the rebuild. The Classic Center can put together the individual parts needed. The major problem is the cost. My opinion is there is no way to justify the expense of a total rebuild for a 1984 380SL. It would be more cost effective to buy a used engine or a rebuilt long block.
1984 380SL
Discussion Starter #13
True, the engine is fine, i just double checked with the mechanic. He is looking for an overhaul kit to get all the seals..etc at once and save us the hassle of looking for separate parts which will be more expensive that way. He is also looking for full body and suspension bushings (this is where i got confused) :)
Thank you very much for the help guys... ive looked at the different options you shared and will definitely be useful
It Is What It Is, Dude
Help us out here. 'All the seals' is still pretty vague. An engine block gasket set would have 'all' the gaskets and seal for the entire engine, but would require pulling and completely tearing down and reassembling the engine.
https://www.autohausaz.com/search/product.aspx?sid=j3vktt55v4dz0wu0g5djjmfp&[email protected]&[email protected]&year=1984&[email protected] Parts, Seals & Gaskets&[email protected]/Lower Engine Gasket Set
What manner of oil leaks are you attempting to address?
Administratoris Emeritus
2021 SL770
This isn't as complicated as these folks are making it sound. Your mechanic wants two head gasket sets, left and right, and a lower engine set. Have a look here: Mercedes M116 Engine Parts.
If we don't have everything you want, please check the BenzWorld Supporting Vendors section for other parts suppliers.
R/C107 Moderator
You are over simplifying it. The question originally was engine over haul kit. To me that means, rings, bearings. valve guides and seals etc. That is what I answered.
1984 380SL
Discussion Starter #17
The leak is very minor and is coming from the rear crankshaft seal.
But i need to replace all body and suspension bushings too as they are worn out..
Cheers
The rear crank seal can be had for 15USD to 20USD online. The lower seal and gasket set I linked has that seal in it, for 95USD. The head sets Germanstar spoke of do not have that seal, he does also list the lower seal and gasket set.
Those are available as pieces, no complete kit though, at any of the links in this thread.
Where on the globe are you? If you go to the UserCP and fill out your profile it does help know what or who to recommend.
1984 380SL
Discussion Starter #19
Thank you..
Ive been looking at different websites and these bushings seem very cheap but i live in Dubai and the shipping cost will be more expensive than the parts price but i think this is still my best option as dealers here will charge a fortune - they make so much margins!
Thanks for the help and sorry for not having the details in my profile, my bad. Details updated now
Yeah, I thought you might be somewhere besides North America. We're spoiled as far as parts availability is concerned.
Among other things. :D
1 - 20 of 20 Posts
