Hello,
Im considering getting into a MBZ, but can only afford to do so at the used level. Im considering between 2 and I thought Id ask for some advice and recommendations from all of you who are more experienced with these cars.
The first is a 1990 300E 4matic. It's in great shape and was made before the Chrysler buyout. It has @ 130,000 on it. I've been told that the head gasket and transmission can be big problems with these.
What do you think?
The other is a 1992 Sportline 190E 2.6 w/ @155,000 on it. Haven't heard much good or bad about this one, but that's why Im asking.
If you have any other suggested models- Id love to hear about them. Ive also heard that the deisel engines are more reliable- is this true.
Any help will be appreciated!
The 1990 300E (W124) is not the 24 valve model (it has 12 valves) and alot of purists find this engine to be more torquey down low. I have this egine in my 1990 300E and I love it except for the blown head gasket (common on this model) which needs to be sorted out some time soon.
The 1992 190E (W201) 2.6 is a wonderful car and has a near equal power to weight ratio to the 300E due to its smaller size/lighter body & slightly less powerful engine.
If I had to decide between the two I would probably go for the 300E since it is a larger car and has the better engine (though the 2.6L engine is essentially the same as the 300E's as far as I know).
As far as diesels are concerned, the 300 Diesel is bulletproof but I'd recommend the turbo diesel since it is the more flexible of the diesels.
Hope this helps you make a choice, good luck.
