The mercedes Error log say its definitely CCM 1708200926 so it cant be the ECU. as all other systems are ok.The problem is to do with the roof and all other components thats associated only with the roof.
see the error below
The errors are
ECU MBnumber Result
CCM- 1708200926 Failed
Vario Roof 1708200926 Failed
PSE 1708000548 Failed
For the roof the code are
1. B1121: component S21s2 right front power window
switch is operated for more than 25 s or cable has
(some funny symbol)
2. B1010 : The supply Voltage of the control unit is
too low (under voltage)
3. B1270: component s69 /9 ( trunk lid open limit
switch) and S69/7 (left trunk lid closed/Locked limit
switch) or components s69/9 ( trunk lid open limit
switch) and S69/8 (right trunk lid closed/locked limit
switch) are operated at the same time
4. B1272: implausible signals from components s69/1 (
vario roof closed limit switch( right lug))S, 69/2 (
vario roof locked limit switch( right
rotarytumbler))s69/3 (vario roof locked limit switch (
left rotary tumbler and S69/11 ( vario roof raised
/lowered limit switch)
5. B1273 : implausible signals from components s69/1 (
vario roof closed limit switch( right lug))S, 69/7 (
left trunk lid closed/locked limit switch)S69/8 (right
trunk lid closed/locked limit switch) and S69/11 (
vario roof raised /lowered limit switch)
6. B1274 : No limit switch signal
And finally
B1279 component s69/2 ( vario roof locked limit switch
( right rotary tumbler)) or S69/3 ( vario roof locked
limit switch ( left rotary tumbler)) is operated for
longer than 25s or lead has -//-or ¬¬ + or ¬¬-
