Looking at a 81 300TD
511 Views 4 Replies 3 Participants Last post by  jdc1244
There is a local transmission shop that has the above car in front with a for sale sign in it. I stopped and looked at it, my son just turned 16 and we are looking for a 3rd car. I have never driven a Mercedes, so I don't know to much about them. It ran a little rough, but its a deisal so that might be normal. What I am really unsure of is that when you slow down to stop,or down shift there is a pop noise. Also when you put it in gear with the brake on it kinda "bows" up in drive and reverse. It has a cheap paint job and needs some cosmectic TLC. It has 198,000 miles and he is asking 1200 or best offer. Like I said I am clueless about Mercedes autos, any advice would be helpful.
Thanks,
Buzz [:)]
The 123 diesel wagon, 300 indicates a 3.0 L five cylinder engine, T for touring – European for wagon (not ‘turbo’) – and D of course for diesel, made from 1980 to 1985 produced 125 bhp with the turbo.
The behavior you describe can be a needed transmission vacuum adjustment. Because there is no vacuum in the diesel’s intake manifold – unlike a gas car – a vacuum device is used to create the needed vacuum to shift the gears. The system is integrated into the car’s vacuum system and the engine’s throttle control. If the system is leaking or otherwise out of adjustment, hard shifting and flaring can occur.
The price is not as important as what a knowledgeable MB mechanic says about the car, it needs a through inspection concentrating on the undercarriage and suspension. Service records would also be nice but at least the mechanic can tell if there was abuse or neglected.
The engine’s supposed to run smooth – the rough operation may be due to a needed valve adjustment (they are not hydraulic) or dirty fuel (2) filters. Watch out for rust.
Also post in the 123 forum for more input.
Welcome and good luck.
BuzzKutt - 2/23/2005 6:45 PM
There is a local transmission shop that has the above car in front with a for sale sign in it ... What I am really unsure of is that when you slow down to stop,or down shift there is a pop noise. Also when you put it in gear with the brake on it kinda "bows" up in drive and reverse.
Thanks,
Buzz [:)]
i'd be concerned if a transmission shop was selling a car and its transmission was acting weird.... move on!
Sorry I will repost in the appropriate forum. And thanks for the info.
Buzz
Nothing to be sorry about – we’re the friendly forum…[}:)][;)]
It’s just that there are more 123 owners there who can give you more feedback.
