1 - 18 of 18 Posts
2005 Mercedes CLK320
Hello folks,
I feel like I am in bad movie. I have a nice looking Mercedes sitting in my driveway that is nothing but decoration because I cannot open it. I recently have gotten a company car which means that the Mercedes is rarely being used right now.
I realized last Saturday morning that the battery had died. I jump started the car and drove around in it for about an hour in order to run errands and recharge the battery.
Well, the next day when I wanted to open the car with my key fob, it would not open. I figured I have to jump start it again and wanted to open the car with the mechanical key. Guess what, the mechanical key didn’t work. I have turned the key many times, have applied WD-40 several times, but it still does not open. I called a locksmith and he told me that it doesn’t sound like he could help me.
All I need is open the door so I can open the hood and jump start it. Does anyone have any suggestions what I need to do? I find it absolutely crazy that I am locked out of my car just because the battery died. I can open the trunk with the mechanical key so it must be the correct key.
1998 MB E300TD, 1997 MB E320
Hello folks,
As you turn the key, pull the handle. It will unlock. Do it at nearly same time.
That does not work for me. I have tried that about 100 times at this point. I sprayed a bunch of lock ease into the lock now but nothing moves even a little bit.
Anyone have another idea what other options I have besides having it towed to the shop or breaking into me own car?
There should be a way to connect the jumper underneath the car, to give it temporary power so you can use remote to unlock.
Alternator power and ground would be a good start. Or any other exposed positive cables down there... Don't use the starter cable!
Do your rear seats fold down? If so, crawl through the trunk, over the seat backs and open either front door manually.
Did you try mu suggestion yet?
92 190e 2.6 Sportline, 2005 clk55
He has a Cab
On my 190 I gave up on the lock and used a large set of channel lock pliers grabbed the end of the key and turned it back and forth until it broke loose. Keep in mind that this was the turn lock and I didn't care if the key/lock broke.
Problem solved. Had a company come out and look at it. They just put a cushion between the rear and front window to create a gap and put a rod through so they can pull the door handle until the door pops open. Took him 20 seconds. At least I know what to do next time.
2004 CLK 240 Coupe
Glad it's fixed.:)
How big was the gap? I'm surprised that the window glass did not break!
Glad it's fixed.:)
Thanks. The gab was probably not more than 1/4 inch. The guy told me that you have to be very careful not to break the windows. Especially with convertibles. I have now hooked up the car to a trickle charger in the garage. Live and learn. :wink
Thanks for everybody's help.
2007 CLK350 cab
I have the same issue right now. I’m so tempered to try this but afraid with my luck I will 100% break the window, probably both of them.
2006 CLK 350 Convertible
I would suggest you look into replacing the battery.
help please have a 2004 clk convertible took battery out to charge realised after shutting bonnet car is locked had this before had to break window to get in tried key in drivers door trick does not work cant afford window replace this time please help
2007 CLK350 cab
Call a lock Smith/tow truck. They can open it. Or you can call aaa sign up for their cheapest package and then you can have them show up and open the door.
1 - 18 of 18 Posts
