1 - 1 of 1 Posts
450SL
Does anyone have any leads on finding the wiring harnesses for a 1976 450SL. I'd like to replace all the wiring in my engine compartment because it is brittle/frayed etc. (Note the red electrical taped "in the meantime" fixes.) I've already replaced the distributor cap, ignition wiring and starter. Complete harnesses are preferable, but components to build the harnesses would do.
Also, I need whatever keeps the power steering pump from leaking from the top also (gasket, correct nut, whatever). Note the yellow "in the meantime" fix. Any ideas?
1 - 1 of 1 Posts
