Originally I wrote yes, it's easy to drop the lower oil pan to access the oil sensor (B40) inside. Then I read the WIS for your model, and discovered that you might also have to remove the front axle gear...Does anyone know if this is something that can be repaired at home.if so how ?
Thanks any idea of costOriginally I wrote yes, it's easy to drop the lower oil pan to access the oil sensor (B40) inside. Then I read the WIS for your model, and discovered that you might also have to remove the front axle gear...![]()
Take a look under the car and check out what is under the oil sump. If the axle gear is obstructing the pan, this looks like a shop job.
