hi folks, can someone explain these symptoms to me and a possible cause please?
1. from cold, slight engine missfire, with reluctant acceleration. fine after about 5 minutes
2. when warm and sitting at idle the engine still stumbles with a missfire. its subtle but just not right
3. when i operate the engine, to rev it from the engine bay, it goes to limp mode and has to be restarted, then all is fine again - still with a subtle stumble though. am i pypassing some clever piece of electrickery by not using the accelerator peddle?
things i've tried:
1. new distributor caps and rotor arms
2. all leads checked for resistance levels - all fine. checked from distributor cap to spark plug connector, ie the whole cable.
3. spark plugs changed
4. coils changed
5. wiring harness is fine and each injector seems to be pulsing fine (listened to them via stethoscope with my indie)
6. cleared fault codes, nothing else listed (although it did have a MAF reading issue - but it cleared ok)
7. checked fuel pressure - fine, 50psi
8. replaced fuel pressure regulator - this helped as it stopped the car from flooding, which it did in very cold weather.
9. terraclean helped but not cured
the car still pulls fine and has never let me down but i just know this is not right and want to get to the bottom of it. could it be any of the following and how do i check them please?:
1. catalytic convertors
2. a dodgy injector
3. MAF
4. throttle body actuators (not really sure what they are but i am concious of some of you on here saying you had issues with them)
5. faulty engine mounts
6. something else?
thank you in advance for anything you can offer to help.
things i've tried:
4. coils changed
2. a dodgy injector
3. MAF
6. something else?
