Limited Slip Differential
3089 Views 5 Replies 5 Participants Last post by  pokerface x
I would like to know if my 1993 600SEL has a limited slip rear differential. How can I make this determination? [?]
86 560SEL
Your car is equiped with 'traction control' and you'd notice a yellow triangle light flash...
Your car is equiped with 'traction control' and you'd notice a yellow triangle light flashing in the middle of the cluster mean it's doing it's job when you're on slippery surface.
1995 MB S320V: 2006 kawasaki vulcan 900 lt
limited slip
newby:
if you get out your vehicle data card,(last page in your maintenance booklet) and look at the list of numbers at the bottom. if you have #256 in there then you have limited slip.
Barry
2001 W203 C240
Re: Re: Limited Slip Differential
Is ASR the same as "limited slip"?
LSD is the mechanical predecessor..
ASR is a traction control program based off ABS. ASR *attempts* to mimic LSD.
