G
After reading all the posts I've decided to change the shocks to Koni's. I'd like to install myself to save some $ but I need to know how difficult a task it is on this car. I've changed shocks on an old jeep and an old chevy p/u but from glancing under the car I would deduct this is a much more involved procedure. Can you advise me? Thanks
G
Discussion Starter · #2 ·
Changing the shocks is not very difficult on a CLK, providing that you can compress it a little.
G
It very easy since you changed your Jeep shock before. The only hard parts is try to find...........
<br> all the plastic screw that hold the trunk liner and remove the trunk liner to access to the rear upper mount shock.
G
the only thing you need to watch out is that you might need to re-use the factory "black&q....
<br> plastic shock cover because it had the right thickness on top.
G
Discussion Starter · #5 ·
Most likely, your Koni's will not come with a sleeve, so use EVERY part from your existing shock.
