2001 ml430 744 silver
Is there a fuse for the lights behinge the 3 circular (A/C) air flow controls?
WHere is it located: passenger foot or box under hood?
If you know the fuse # that would be great. I wont have to hunt.
Thanks in advance
Super Moderator
It is just one bulb and they do burn out. Gently pull off the center dial and you will see
it. The bulb is lees than $2. To remove to old bulbs I us a piece of 1/4" tubing and get it
firmly on the bulb. Then just remove it.
If nothing else has ceased to function then it is the bulb and not a fuse. Dealers stock them.
They are used in a lot models.
