1 - 9 of 9 Posts
Hi All:
I occasionally think of changing the wheels on my 02 E430. (I have the stock 17 inch wheels.)
I was told that lighter wheels are better wheels as it creates less rolling resistance as well as reduces the weight of the car in total. (Not that 30 pounds or so is a big deal but honestly, which of us would not like to be a bit lighter?);)
Is this correct?
Also, would I feel any difference and/or benefit by going to an 18?
Thanks all.
'01-E320 & 02-ST2
It isn't the weight so much as the UNSPRUNG weight, which is much more of an impact on ride and handling.
Generally speaking 18s are heavier and result in a harsher ride.
Buy the lightest wheels your budget will afford, when you see the prices on light 18" you may change your mind.
Take care and enjoy the ride,
Greg
The subject of bigger wheels has been discussed ad nauseum. As Greg stated, and in general, the bigger the wheel the harsher the ride. The Mercedes engineers are not idiots so why second guess them? In other words, the wheels that originally came on your car provide the optimal handling, ride comfort, and safety. If you don't like the style, at least stay with the same diameter. I'm not that happy with mine (10 spokers which I think are an aesthetic disaster), but I think 16" on my car is the way to go. If you think larger looks better, fine and it's your money, but you'll be sacrificing the other benefits of the OEM size.
'01-E320 & 02-ST2
MM, the 16" split spokes from the 211 look awesome on the 210, very classy look and lots easier to clean...
Greg
Hi Greg, dis-ease (Is that a word?) of cleaning these puppies is another reason I don't like them, too many nooks and crannys. Thanks for the suggestion and I'll have a look at those.
'01-E320 & 02-ST2
Since you have brilliant silver, this is how they'd look...and they pop up on CL and ebay for very good prices. You can put your current tires on them just fine, add a set of $60 rad custom lug bolts and you're all set. :)
Greg
W203, W210 Moderator
E55 ///AMG
Hi All:
Is this correct?
Thanks all.
Like everybody says, less weight = less rotational inertia.
http://www.benzworld.org/forums/general-mercedes-benz/1222257-what-benefits-larger-wheels-tires.html
2002 E430 4-Matic
a simple rule of thumb regarding the weight of wheel/tire is 1lb in the wheels = 2lbs anywhere else.
Reason is you need to energy to accelerate the rotational mass and additional energy to accelerate the same mass in a forward vector. In addition you also have that additional evil of more unsprung weight.
03 E320 4M Wagon & 97 E320
Figuero is right on.
In addition to handing (as Greg correctly mentioned), there is another effect of the rotational unsprung weight (wheels, tires, brake rotors, half shafts, etc) on acceleration and braking.
The absolutely correct term that should be used here is unsprung mass but we are not going to space or another planet so let's be partially wrong by using weight. Please do not comment on this part because the general public is so confused on this.
The equivalence of 1 lb of rotational unsprung weight from EACH wheel is 2 lb of static weight is actually the worst case scenario. However, it is not too far from the real value of 1.7 lb to 1.9 lb, depending on wheel design (weight distribution).
In some old hot rod magazines, they quote numbers like 1 lb of wheel weight reduction is equivalent to 6 lb or 8 lb of static weight. That is right but often interpreted wrongly. There are 4 wheels in a car so if you reduce 1 lb from each wheel (and 1 lb is equivalent to 1.5 lb or 2 lb of static weight) and that is why they have the 6 lb or 8 lb numbers. So 1 lb of reduction in wheel weight is still equivalent to 1.5 lb or 2.0 lb reduction in static weight. There are just 4 wheels.
Here is an ideal case but it help understand this situation.
Let's say someday they design a (super strong) plastic wheel that is extremely light (assume zero weight for this discussion), then the wheels weight would have no effect on acceleration.
Now why the 1.5 lb or 2 lb numbers? First of all, the 1 lb in the 1.5 or 2 lb is simply the weight of the wheel itself. In another word, if the wheel slides (no ABS, LOL), it would behave just as the true weight of the wheel.
When the wheel rotates, then additional energy is required. The effect is the same AS IF the wheel is heavier now.
If the wheel WERE a disk, i.e., mass uniformly distributed across everywhere, then the effect is 1 lb for 1.5 lb. I am not going to show the calculations here but the moment of inertia for such a disc is 0.5MR^2 and that is where the extra 0.5 lb comes from. To get the full details, we would calculate the motion of the wheel as a combination of a linear (straight line) motion and a rotational motion. The angular speed (rotational speed) is related to the car speed (linear speed) and the radius of the wheel.
If the wheel WERE a hoop, i.e., all the mass is on the rim, the part that touches the tire, then the effect is 1 lb for 2 lb. (The moment of inertia for a hoop is MR^2 and that is where is extra 1 lb comes from).
Most modern alloy wheels are neither discs nor hoops but they are closer to hoops than discs because the modern alloy is very strong so not much weight is required between the center of the wheel and the rim of the wheel. So that is why 1 lb is more like 1.7 lb or 1.9 lb, depending on wheel design.
Now the lighter the brake rotor, the faster the acceleration. It has the same effect as wheels and that is why car makers are making the rotors thinner (lighter) and thinner (lighter).
Although the crankshaft pulley and others are not technically unsprung weight, they do have similar effect from an energy consumption point of view.
In the other W210 forum, Figuero and I had some fun with a vendor who claims (big) power increases with their crankshaft pulley.
1 - 9 of 9 Posts
