My car is an early 600 coupe. Currently off-road, as the attempts to recommission it have stalled.
California-spec, which means faults in the emissions equipment trigger the nasty red CEL.
I am at wits' end - fixed almost everything else, but cannot get rid of the 023 code, logged in both the LH and DM modules (DM 021 and DM 053).
The regeneration switchover valves y58/2 and y58/3 in the MB language are what we also call purge valves or MOT valves. They are simple solenoid valves, which I've taken to the bench, cleaned, tested.
Startek gives the following description of the fault:
Left or right purge control valve (Y58/2 or Y58/3), open/short circuit
Well, the valve has a simple 2-pin connector, with pin #2 being a red/blue power wire (from the Basic module), which I have confirmed is live at idle.
Pin #1 is red/brown signal wire from the LH modules, and I believe my problem is here.
If I understand the wiring diagram correctly, this is a DIRECT connection between the plug for the purge valve and the N3/3
But, with my ohm-meter, I cannot confirm continuity between pin 38 of the base of the N3/3 module and pin 1 of the y58/3 connector.
Same issue with the N3/2 and y58/2. Power is confirmed, but the wire that should be providing the cycling signal from the LH module is broken.
Is there anything that I am missing?
Thank you for your help.
