Hello,
I am about to fit a new level control valve block into my R350. It's my last option as I replaced the right front strut and it is still sagging to the right.
According to the manufacturer's manual you will have to remove both grille and front bumper to get to 2 bolts which hold the block or its bracket.
Is there any way around removing the entire front bumper? Anyone succeeded in removing the valve block without removing grille and bumper?
Your comments are appreciated.
2607692
Discussion Starter #2
In case someone wants to replace the valve block like I did: you can reach the 2 screws which hold the valve block to a bracket from the top (engine compartment). The upper one is easy, the lower one is a b*tch. A small needle nose vise grips is your best friend here probably.
