1995 E320 Wagon, 2002 S430
Wondering what might cause the trouble code LED flasher to become inoperable? You know, the one under the hood next to the battery compartment? Also, I just found a blown 30 amp fuse on the fused green relay under the hood under the fuse/relay cover... next to a blue fused relay, another green relay (non fused) and some other relays (two white relays and a very long black one). There is def something grounding out on this car causing shorts because I have had to replace the E fuse on this car twice already (think it was E) in one week -- the elctric seat recliners don't work when it is blow. Any idea as to what might be causing this to blow?
