I am looking to buy a set of LED tail lights for my 2011 C300 Sports Sedan. I have seen some on ebay that sell for about $220, but only from 2008 thru 2010. I was wondering is they would fit on the 2011. The reason I am asking is becaus I found some 2011 LED tail lights, but they are $450, twice as much. But they look exactly the same.
Has anyone gone ahead and still purchased the 2010?
MERCEDES C-CLASS W204 RED CLEAR LED L.E.D. TAIL LIGHTS | eBay
above link is the 2010, below link is the 2011
CG® - Red/Smoke LED Tail Lights - W204 - 2011 Mercedes C Class CG LED Tail Lights - CG 03-MBZC08TLEDRS
What you have to look for is 2 things. One: does your 2011 have LEDs stock? Two: are the LEDs that you're interested in have built in resisters to work properly with your car.
Some will say that the lights won't work in cars that already have LED system. So you want to make sure if you don't have FACTORY LEDs then you should be fine with the upgrade. And yes the tai lights should fit unless it is AMG OR 2 door
