1 - 10 of 10 Posts
1997 S420 Midnight Blue 113,000
I used the Leatherique 2 bottle kit exactly as described. The rejuvinator oil that was supposed to "lift away the dirt". then the conditioner. I was not overwhelmed with the results, either by the cleaning process, or by the supposed suppleness. I then repeated two additional times, used a soft bristle brush assuming that would make a difference. left the car indirectly in sun with windows closed to heat up the process. I am still not thrilled. Am I better off with a cream or different product? ...am I doing something wrong? This is a 1997 S420 with 72,000 miles.
1998 E300D
pcunningham42 said:
I used the Leatherique duo exactly as described. The rejuvinator oil that was supposed to "lift away the dirt". then the conditioner. I was not overwhelmed with the results, either by the cleaning process, or by the supposed suppleness. I then repeated two additional times, used a soft bristle brush assuming that would make a difference. left the car indirectly in sun with windows closed to heat up the process. I am still not thrilled. Am I better off with a cream or different product? This is a 1997 S420 with 72,000 miles.
I don't know how "hot" it was the day you made your attempts....you don't mention it. I can suggest doing it on a hot day (let's say 80F) and leave the car in the sun all day. I'm also going to suggest covering the leather seating surfaces with plastic bags to effectively steam the seats. You should be seeing some noticeable improvement.
There are stronger products. Here's one to consider:
Aged Leather Revitalizer
Problem is, when leather truly gets dirty following years of neglect, it can be a real chore to correct. Leatherique is one of the more potent leather products I've tried. Use stronger products with caution.
Thank You...I actually did the plastic bag trick and left the oil on 48 hours. It seemed like it dried into that white gummy substance pretty quickly. I guess I'm used to taking a new baseball glove, warming it up, putting the glove oil on it and its like butter after 24 hours. I'll try again this weekend as its supposed to be 75 degrees. I also found that the cracks seem to get darker now on a slate grey leather interior. Any view on sheepskin covers?
1998 E300D
Yeah, they tend to sand the leather right down :eek:
George, owner of Leatherique, suggests using a couple of ozs of the RO per seat. Make certain you wear gloves when using that product.
I don't know what the white gummy substance is you're referring to. As garbage floats up out of the leather, he said sometimes it appears white.
Be honest, what sort of shape are the seats in you're working on?
1999 SLK230 Sport
I dont know if it is really something you are doing wrong. The results you get will be directly affected by the condition of the leather when you started. This is a 10 year old car and if the leather has not been cared for for many years, you will get just so much out of your efforts no matter what you do.
1984 380sl, 1988 300ce, 1988 420sel (gone)
I just used Leatherique myself and it is not a one time affair if you have older leather that's not been maintained. I thought my leather was pretty clean (its cream coloured to boot) until the first time I used Leatherique. I was actually a bit horrified at what came up after it has been sitting for a bit. I cleaned it with the pristine clean - okay it looked a little better and the leather was a bit softer. Followed up the following weekend with another round of conditioning and cleaning- looked even better and the leather was a bit more softer. Leatherique does recommend 2-3 sessions so I will follow up with a third session.
I have notice a definite improvement in the colour and softness of the leather. I could be wrong here but I don't think the leather, at least in the older mercedes, is that soft to begin with.
1998 E300D
These are both excellent and relevant summaries :thumbsup: If you're working with seats that are already wasted, there's no potion that's gonna restore them. You might end up softening and cleaning the leather a bit, but, if the seats are a mess, nothing short of professional restoration (dyeing, sanding) is going to make them appear new.
I worked on an '00 Passat this weekend that has never had any care whatsoever. The driver's seat was clearly dirty, pass. front seat showed some age, rear seating surfaces appeared new. This was light grey leather, car resides in a very hot area which is even harder on leather.
We spent about 1/2 hour working with Griot's product and the Prestine [SIC] Clean. I'll tell ya, even I was impressed how much they cleaned up. :) The arm rest was very dirty, certainly the worst area. While the driver's seat showed a decent improvement, it certainly wasn't as nice as the rear seating area. If I had more time and more heat, I could have gotten that driver's seat back to excellent condition. I'm having the owner order up a few products and he'll continue with follow-up treatments and hopefully liberate a bit more dirt from that driver's seat. Being in a hot climate, I've suggested he treat the seats at least every quarter with the Griot's one step product. Once he get things back in shape, heroic cleaning measures simply aren't needed :)
Remember, car care and car detailing are significant undertakings should you wish to keep things at 110%. You can't decide one day, when the car is 10 yrs old, that you're suddenly going to start taking care of it and expect a flawless result. Reality dictates that you've got to care for the leather and paint (and everything else) throughout the year, every year ;)
HTH
Discussion Starter · #9 ·
The seats are in great condition, no rips or tears. Color good. It is a low mile 72,000 station car. After hearing all the above...I'll give another try. I trying to decide however, once I'm fairly satisfied, do I get sheepskins..? I do plan on making this my last car.
2000 e320 4matic
I love my sheepskins. Don't buy a cheap set (costco, etc) or you may be disappointed. the cheap ones tend to rub off on your pants.
1 - 10 of 10 Posts
