92' 300sl
Hi, i just got my 92 300sl one month ago and i took the hard top off recently. the other day it rained and i noticed that my top was leaking. it was actually leaking from the top of the bar where the upper corner of the windshield meets with the soft top. ill point out where in the pick thats attached. if anyone knows what i can do to fix this please help... thanx
by the way the picture is not my car i just found any pic off the net...
Hi, i just got my 92 300sl one month ago ...
Yeah, mine too. You can re&re the old seals, clean and use new sealant under them if they are in good condition but it is best to replace the old style 3-piece windshield frame weatherstrip seals with the updated one-piece seal. Also have to check that the water is not comming in from above the hardtop seal. If you do take apart the old style of seals be sure not to forget to put the L-shaped water deflectors back in the top corners of the seal joints.
92' 300sl
Thanks for the info, ill let you know if i run into any troubles......
