1998 sl500
My 98 SL500 has a problem with the windshield washer resovoir losing fluid. Any ideas on removal or easy fixes???
Sith Lord
72 280SE 88 560SEC 92 E500 6.0 95 SL320 14 GLK350
If I recall, there are 2 screws to remove it. Just take easy on the different hoses.
If the leak is minimal, dry it well under direct sunlight, and try two-part heat resistant epoxy.
1998 SL600, 2015 GLK250, 2014 RAM1500 EcoDiesel
My leak was from the grommet that holds the washer pump suction inplace. Easy change. I could just lift my reservoir up to get to the pump.
2010 SL63 AMG, 2001 SL500, 2012 Corvette Z06, 2013 Lexus RX350, 2012 Cadillac CTS Coupe, 2015 Ram
There's a plastic knob on the side of the reservoir. Undo it and the whole tank lifts straight up, with hoses attached underneath.
FYI, this is also how you get access to replace the headlight bulb on that side.
Greek God of the R129
SL500-500SEL-190E
If the leak is from the pump grommet you can buy only that part for cheap.
Regards,
aam.
1998 sl500
Thanks, having you guys with all this info makes owning the SL soooo much more affordable and fun
