88 200 (A); 93 280E (A); 96 E250 D (M)
This is my first post and want to say this is a great forum. I have been the proud owner of a 1990 300SE for a week now and am bowled over at what a great car it is when compared to a 116 or 123!!
I have water in both sides of the trunk and found the tail lights to be the culprits. I suspect it is the tail light seals. Is it good enough to use some body sealant or should I replace the seals? also how tight should the nuts be?
I will also replace the trunk seal as a precaution. There is only a small amount of surface rust, which I have treated with a converter.
Thanks. All help appreciated.
Greg de Klerk
81' 300SD, 82' 300D
The tail light gasket part number is: 1268260091, that's for both sides.
· Always Remembered RIP
2015 ML 400 x 2
Replace the seals - fairly cheap and squirting sticky goo is not the way to repair these cars.
Good replacement parts fit and do the job they should.
Cheers and good luck.
