leaking oil cooler line
1983 300D 5 cyl Diesel
I Recently had to remove the lower oil cooler line to pull the oil pan.
When I put everything back together, all is well Except the Lower oil cooler line Leaks like hell.
I've tried reinstalling twice but it still leaks.
Any advice much appreciated[:D]
1984 300D Turbo
suggest you replace as if it fails at highway speed all the engine oil will disappear almost immediately and you will have a blown engine in no time flat.
in the meantime keep a very close eye on your oil pressure gauge as you won't have much time ie. seconds to shut down the engine if you lose oil pressure.
